PXI
Method for measuring low value of RPM using counters
I need to measure frequency of low values,which is the best for obtaining a low value of RPM,the hardware used is NI-PXI 6602 card.
(3,319 Views)
There are examples written for measuring the frequency of TTL signals. If you are using LabVIEW, you can search the data acquisition examples and you will find a separate folder for counters (...Program Files\National Instruments\LabVIEW\examples). There will be a NI-TIO.llb which will contain all examples you can use with the NI 6602. There is a Measure Frequency VI that will work for you. For text-based programming environments, there will be examples installed within the ...\Program Files\National Instruments\NI-DAQ\Examples directory. I hope this helps.
Todd D.
(3,319 Views)
