PXI
Multi-chassis synchronisation
I am trying to spec up a system with three or four PXI chassis, with a single RT controller connected together by MXI daisy-chains.  I'm aware that the MXI connection doesn't distribute the clocks and triggers.
The system is a sort of HIL test, so there are various injection points and signals from the HIL that I need to read back.  What I'm trying to work out is what I need to do, if anything, about synchronisation.  My current options seems to be:
  • Try to synchronise everything up at the start of a test (tests are order of minutes) and then assume the clocks don't drift too much
  • Use synchronisation cards to sync across all the chassis - this looks preferable, if more expensive.
The problem is, I can't find much information on how this all hangs together in practice - what cables do I need to run around the test rig?  Is it a daisy-chain or a star from a master card?  Do I need equal length cables?
I've found some very old descriptions with very old, unavailable cards (dating back to 2002) but wondered if there is more up-to-date guidance relevant for current kit?
(2,332 Views)
Ever get an answer? I'm wrangling with a similar problem myself.
https://forums.ni.com/t5/PXI/PXIe-multiple-chassis-triggering-with-6674T-and-no-TClk/td-p/3893457
(2,201 Views)
