PXI
Multiple PXI
I have four PXI-chassis, connected by ethernet, and I would like to read channels from chassis number 1 (for example) and write on number 2.
I read that we could use VISA protocol to automatically communicate to the distributed PXI systems, but i can't get it!
How can I, through ethernet, get a channel of a PXI card of a PXI chassis?
(3,142 Views)
Could you be more precise about the configuration you use, and what you would like to do.
Which type of PXI controlers do you use? And Which software do you use to acquire and generate signals on your PXI?
Are you using Windows or RT configuration ?
Olivier L. | Certified LabVIEW Developer
(3,129 Views)
