PXI
Multisim in real time FPGA
Hi All,
I am trying to co-simulate a multisim file into Labview.
Its working but the moment I select that VI to run in real time FPGA , everything codded in labview works but the multisim block stops talking to my PXI.
I do not understand why is this happening. Can anyone help me.
A.A.K
(5,813 Views)
Hi A.A.K,
Can you send us your files. It you do not want to share them on the forum, you can go to www.ni.com/ask and create a Service Request.
Tayyab R,
National Instruments.
(5,799 Views)
Hi Tayyab!!
Files are attached. Its simple PWM genration from multisim called in VI.
Tell me if co-simulation does not support FPGA at all, because the multisim block always stops running whenever i connect to FPGA (PXI-7813).
AAK.
(5,791 Views)
Hi A.A.K,
The Multisim co-simulation is intended to help you simulate the circuitry for your system but it is not possible to add this on the real time target device(PXI in this case). You can still test along side your FPGA code on your computer and test the system but it can't be launched into target devices.
Hope this helps.
Tayyab R,
(5,778 Views)
Here are a couple of useful links you can look at. In general, you can use co-simulation with IP FPGA nodes.
Tayyab R,
(5,775 Views)
Thanks Tayyab !
I think I need to start coding  myself.
AAK.
(5,758 Views)
Hi Tayyab !
For now i have started with NI SoftMotion and there I found the Space Vector Modulation block for two-level converter.
For my system I need a SVM for three-level converter for which i am trying to modify that already built-in SVM block.
But the problem is whenever i make a change in any block diagram and see the result it needs to compiled every time which is really time consuming.
I also tried to run this block on real time hardware but it only works with FPGA device.
Can you please device me a short way of editing and checking this block. Moreover, do NI offers any assistance with three-level converter topology.
AAK.
(5,687 Views)
