PXI
My CPU PXI 8145RT boots in Safe Mode!!! (DAQmx 7.4)
I have a CPU PXI 8145RT. I updated my NI DAQ Version:
DAQmx 7.3 -> DAQmx 7.4!
The 8145RT rebootes in Safe Mode.
I tried to reinstall all the software but when I install DAQmx 7.4, afterwards the CPU reboote in safe mode!
What is necessary it that I make? Does Y have to you it an order of installation?
Cordially,
Loïc
EURILOGIC in France
(3,075 Views)
The same question has been replied at the following link :
http://forums.ni.com/ni/board/message?board.id=4170&message.id=2326#M2326
The solution is to format the flash.
Then select all firmwares you want to install.
The installer will then choose the installation order.
regards,
Marc L.
(3,056 Views)
