PXI
My PC doesn't boot with my MXI-3 Interface connected to my PXI-System.
i had the same issue. I fix it by installing MXI-Express BIOS Compatibility Software 1.4.1 and set the PCIE card on Mode 1
Read the Readme file for more details before installing the software.
http://download.ni.com/support/softlib//PXI/MXIe%20Compatibility%20Software/1.4.1/readme.html
Message 11 of 24
(1,499 Views)
Hi All, I,m fighting against the same problem.
What I have:
Chassis PXI 1000B
                  PXI-8330 inserted to 8th slot
                  PXI-6508 inserted to 7th slot
PCI-8330 in one PC PCI slot
I have tested these three different PC:
                   Thin client IGEL, Via processor 1Ghz with 1Gb RAM WinXPSP3
                    Fujitsu Scenic E600 Win2KSP4
                    PC with Asus M597A EVVO R2 mother board with AMD FX-8120-core  WinXPSP3
I start the PXI chassis first.
Start the PC, but it hangs in black screen and no booting. When I stop the PXI chassis it boots normally.
The LEDs whilst the PC doesn´t boots are.
PXI-8330  POWER: GREEN
                   RX: Ambar
                   LINK: OFF
                   TX:OFF
PCI-8330   POWER:GREEN
                    LINK:GREEN
                    RX: OFF
                    TX:OFF
I have installed the MXI-115 driver prior to install the PCi card on the PC
I have tested several things, change the PXI-8330 to another slot, start PXI chassis with PXI-8330 alone, update the Bios of the third PC, change the PCI-8330 to anothe slot
Please can somebody help me?
To administrator, I have post the same message in another thread, so please remove conveniently
Thanks¡
Message 12 of 24
(1,427 Views)
did you tried what i did ?
Message 13 of 24
(1,421 Views)
The PXI-8330 needs to be in slot 1 for it to work with the PCI-8330.
Message 14 of 24
(1,418 Views)
that doesn't matter... did you installed and tried the Compatibility Software  ?
Message 15 of 24
(1,415 Views)
The compatibility software doesn't support MXI-3.  It's only for newer generations.
Message 16 of 24
(1,411 Views)
.Hi Guys, thanks for your ideas
I have tried also with the PXI-8330 in slot1
The result is the same, the pc doesn,t start
Message 17 of 24
(1,402 Views)
With the PXI-8330 in slot 1 you should be getting green link and power LEDs.  If not then you've got a hardware problem.  I couldn't tell before if your LEDs were wrong because the PXI card wasn't in the controller slot.
I don't know whether it's one of the cards or the cable, though.  Do you have any other copies of the hardware (PXI, PCI, cable) to swap with for debugging?
- Robert
Message 18 of 24
(1,395 Views)
Hi Robert, thaks for your comments
I have tested with the PXI-8330 in the slot1. The result is the same.
The thing is, if I have a hardware problem, which is the faulty card?. the PXI-8330 which has not the LINK LED in green?
Unfortunately I don´t have another hardware to do a check
Best Regards
Message 19 of 24
(1,388 Views)
Hi , I have tested the cable with a Fluke, not all of the pins give me continuity
The pin s are showing continuity are;  1, 3, 6, 8
Message 20 of 24
(1,382 Views)
