PXI
My PXI-1052 Chassis is not getting detected in Traditional DAQ?
Dear all,
I am using PXI-1052 combination chassis.
I am able to configure the SCXI modules in DAQmx.
But the same thing i am trying to do with Traditional DAQ i am unable to get the PXI-1052 Chassis in the list.
I am using Traditional DAQ 7.2 Driver.
I tried with Traditional DAQ 7.4 also.
Can i configure the PXI-1052 Chassis in Traditional DAQ????
regards
Preetam
(3,159 Views)
Hi Preetam,
The NI PXI-1052 chassis can be configured in Traditional DAQ by choosing its predecessor, the NI PXI-1011. Once selected, follow the standard process of selecting the SCXI boards that you have installed. When configuring the PXI-1052 as the PXI-1011 in MAX, you need to configure it as both the SCXI chassis and PXI system.
The PXI-1052 was released after the Traditional NI-DAQ version 6.9.3. This is why when you use the chassis with Traditional NI-DAQ, you will need to identify it in MAX as a PXI-1011. Please refer to this knowledge base.
I hope this helps.
Natasa
(3,142 Views)
