PXI
My PXI 8145RT controller does not boot
My PXI 8145RT controller does not boot when I turn the power on. The lamp sighning that power is OK is light but nothing else happens. This phenomenen happens from time to time but after some attempts finally the controller would start working. But the last day nothing happens. Any idea???
(3,922 Views)
Hi
Have u connected the monitor? what do u see on the screen?
Regards
Arun
(3,916 Views)
there is no input for a monitor on the 8145RT controller I have.
(3,914 Views)
Hi Greece,
We definitely need to do a little more investigative work to see what the root cause of this boot problem might be. As you can see, there is a 9-pin serial port on the front of your controller. I've pasted a link to the user manual below -- in which there is a section which describes how to enable a "serial redirect" of diagnostic information. Essentially, you can connect the port to a serial port on your PC (configured with the appropriate comm settings) and view the diagnostic output through a terminal application (such as Microsoft's Hyperterminal). This will tell us more about what might be happening. Please give this a try and let us know what you find.
Thanks!!
http://digital.ni.com/manuals.nsf/websearch/6EF72E1DA17CB52A86256A8B006399F2
Best Regards,
Alan L
(3,898 Views)
Hi Greece
Well i feel there is a problem with the power supply. And if you gone through that power supply i.e.SMPS in the PXI is OK then you may format the drive & re-configure it. Any file may be currupt or your PXi is not configured properly.
Love Diwan
India
There is always a better way to do things.................. "Just Find It"
(3,864 Views)
