PXI
NI 8353 noise issues
I have a NI 8353 controller with 4 250GB disks. The disks themselves make a lot of noise in operation. Is there a way to spin-down or reduce the speed of the disks somehow when they are not being used to acquire data ?
Thank you for your help,
Chris
(3,539 Views)
I found this link that may be useful for you:
I am not entirely sure that it can be applied for RAID disks though.
KostasB
NIUK Applcations Engineering
(3,525 Views)
Good suggestion, however at the moment I'm stuck using the XP installation that came pre-installed on my controller. The Intel Raid software installed has no options for disk spin-down, I may have to move the controller to a different room, and run some long extension cables.
Chris
(3,509 Views)
