PXI
NI-DAQmx
I am using NI-DAQmx with PXIe-4481 and PXI-1073. I want to acquire data using c++. When I installed the 32 bit library and dll was installed by default in my win11 64 bit system. I want to combine it with libtorch c++ which has 64 but libraries.  Is there any way I can get 64 bit libraries for DAQmx? Also some examples of c++ codes in NIDAQ-mx
(2,169 Views)
See Getting Started with NI-DAQmx for Text-Based Programming
For 64-bit libraries, change AdditionalLibraryDirectories="$(ProgramFiles)\National Instruments\Shared\ExternalCompilerSupport\C\lib32\msvc to (ProgramFiles)\National Instruments\Shared\ExternalCompilerSupport\C\lib64\msvc
https://tmesystems.net/
(2,142 Views)
There is no folder called ExternalCompilerSupport in "Shared" folder. The library in my case is in "C:\Program Files (x86)\National Instruments\NI-DAQ\DAQmx ANSI C Dev\include".
(2,139 Views)
Make sure the package NI-DAQmx Support for C is installed. If it is not, go to the PACKAGES tab to install it.
(2,136 Views)
 I have it installed.
(2,133 Views)
I am not sure why you don't have those folders. I would recommend you reinstall the DAQmx driver
(2,122 Views)
Did it just now. I am using 2023 Q2. You?
(2,119 Views)
