PXI
NI DMM Soft front panel did not detect any ni-dmm
has anyone seen this failure? I can´t open soft front panel to setup the dmm. I tried to reinstall VISA and NI-DMM without success.
Robert
(7,585 Views)
I had this, or similar last week.  I gave the computer running LabVIEW the three-finger salute, and all was fine.
From what I understand, rebooting the computer ensures that the PXI chassis is up and recognizable to the computer bus.
Jeff
Robert
Jeffrey Zola
(7,576 Views)
reinstalling the nidmm and visa will cause several reboots of the system. That was no solution
for me and my problem.
After starting the nidmm, the window with the information, that the 4072 won´t be found shows
a RESCAN button.  By pressing the RESCAN button, the error code -1074118656 and the message,
that the device ist not recognized and this version or driver wont fit my 4072.
Should I install the only install the delivered driver or could I update to the actual version?
Delivered was Version 2.5 of NIDMM, installed on my system is the actual one from the NI homepage.
I think, I try to deinstall the NI-SW completely and install "only" the delivered SW. Hope, this will solve.
Robert
(7,566 Views)
Hi Robert,
the procedure would be:
-  make sure to start PXI first then PC if using with MXI-card, otherwise start PXI controller
-  make sure to have administrator priviledges on your System
-  check if the PXI-4072 is actually accessible by the system
   1.) check MAX
   2.) if not present in MAX check device manager
  if both fails uninstall the NI-DMM and install the latest NI-DMM driver (download at ni.com)
- if the 4072 is correctly shown in MAX, execute the selftest
-  if everything is good, start DMM Softfrontpanel
- does it still not recognize any DMM --> uninstall NI-DMM and install latest NI-DMM driver (download at ni.com)
best regards
Marco Brauner NIG
(7,561 Views)
Accepted by topic author DBD
Robert,
What happens when you run Self-Test on the PXI-4072 in your system?
Also, if you rename the PXI-4072 to a different name ("4072", for instance), does it work?
The 4072 in your system looks like it may not be installed correctly. The icon that it shows in MAX is the generic PXI icon, not the icon that NI-DMM devices should show (my apologies, but I cannot remember the terminology). Additionally, the 4072 should show as 3: NI PXI-4072 "PXI-4072". Yours is showing as 3: 4072 "PXI-4072". See the image below for how it should look:
Please let us know if this helps.
Tobias
Principal Software Engineer
Driver Software
(7,543 Views)
Hello Tobias,
as you describe, the icon of the pxi card show, that the card driver was not installed correctly.
Reinstalling the driver solves it.
Thanks for your all support
Robert
(7,512 Views)
Robert,
Glad to hear it!
Please let us know if we can be of further assistance.
Tobias
Driver Software
(7,500 Views)
