06-15-2010 02:20 PM
From NI Spy during external calibration of PXI-4072 using CVI version, compile 8.1, CVI runtime 9.00.
Everthing upto this point is VI_SUCCESS
Then line 6 turns "red"
5. niDMM_CalAdjustLC (PXI1Slot11, 4)
Process ID: 0x000009D4 Thread ID: 0x00000744
Start Time: 12:43:49.328 Call Duration 00:01:26.593
Status: 0 (VI_SUCCESS)
> 6. niDMM_CalAdjustLC (PXI1Slot11, 5)
> Start Time: 12:45:59.875 Call Duration 00:00:33.375
> Status: 0xBFFA420D
7. niDMM_GetError (PXI1Slot11, NULL, 0, NULL)
Start Time: 12:46:33.250 Call Duration 00:00:00.000
Status: 0x00000064
8. niDMM_GetError (PXI1Slot11, -1074118131, 100, "The generated L...justment order.")
06-22-2010 02:57 PM
Hi dh5869,
Is this behavior only with this board? Has it been successfully externally calibrated before? Were there issues with the board to drive the calibration or is this routine? What is the part number on your card? Typically this is 6 numbers followed by a letter and -01. This will allow me to look for any known issues with that board revision.
06-28-2010 08:36 AM
Hello h-Baker,
We have this problem ith all PXI-4072 DMM's during external calibration. We cannot get past this step till we reboot the machine and just run the adjustment procedure stand alone. We have taken the 4072 cal procedure pdf instructions and created a Labwindows CVI program. Following all of the CVI instructions to the letter. The program executes the 2 year performance tests. Then the adjustments, followed by the 24 hour performance test. Unless we start with a just booted machine we get the posted error when we get to the last adjustment steps. We have NI-Spyed the entire program. We get no errors until that last adjustment step which refuse to go through and generates the -1074118131 error. We are at a loss as to what to try next. Like I said if we reboot the PXI chassis and controller and just run the adjustments it will work. Any help with the errors would be appreciated.
06-28-2010 08:48 AM - edited 06-28-2010 08:50 AM
It happens with rev,B,C,or D 4072 DMM's.
We can get them to complete external adjustment, after reboot of pxi-8196 in 1045 chassis.
It is routine to adjust these units on a yearly basis.
The sticker reads 191485B-03 and 191485C-03 on the other. They both throw the same error.
06-29-2010 04:56 PM
Hi dh5869,
Try upgrading to the latest version of NI-DMM as there is a documented fix in the readme for NI-DMM 2.8 that addresses LC behavior. Please let me know if you continue to experience this behavior after upgrading.
