PXI
NI ExpressCard-8360 - Adaptor card to low-profile PCIe slot
i've already bought this startech adapter and it's working well. I'm using it with the PXI1033 and the expresscard 8360.
Message 11 of 18
(4,316 Views)
So no problems to switch off the computer with connected adaptor?
Message 12 of 18
(4,305 Views)
No problem, you connect the adaptor on the computer and let it there, everything you need know is on the manual, just pay attention because you aren't supposed to take the card off with the computer turned on.. it's not hotswap.
Message 13 of 18
(4,298 Views)
Ok. And is low-profile bracket included?
Message 14 of 18
(4,275 Views)
yes, it's included.
Message 15 of 18
(4,271 Views)
Another possibility to order Lycom DT-105 ExpressCard Slot in PCIe Low Profile Adapter in Europe...
They have not it in e-shop but they are able to order. Minimum is 30pcs.
Message 16 of 18
(4,200 Views)
I should 2nd that the startech works fine in Two Lenovo PCs. Kudos. JoãoP for testing it out.
Also the plastic clips
StarTech ECBRACKET2 Stabilizer Adapter
http://www.newegg.com/Product/Product.aspx?Item=N82E16839158051
are well worth it Smiley Very Happy
i recommend the platic adaptor to prevent the MXI cable and hence 8360 getting bumped when in use, disconnecting the chassis.
Message 17 of 18
(2,993 Views)
Hi
I posted a replacement for express card on the idea exchange so it can be upvoted.
http://forums.ni.com/t5/Data-Acquisition-Idea-Exchange/Modern-Upgrade-for-ExpressCard-8360/idi-p/333...
Nick
Message 18 of 18
(2,318 Views)
