PXI
NI-MAX unable to find Chassis
I have NI PXIe 1071 chassis and one multifunctional DAQ module. I am using NI-MAX to detect my chassis. But I can't find the chassis under device and interface. I am connecting PXIe chassis with PC via ethernet port. What is the problem behind it?
(1,504 Views)
Since you use a Ethernet cable connecting to it, I guess you have a PXIe embedded controller on the slot 1. Connect a monitor to that controller and see if it is running a RTOS or Windows. If it is a Windows, you can omit the PC and use that controller as the PC. If it is a RTOS, the IP address should be shown on the screen. Try to detect the RT controller under the Remote System in NI MAX.
https://tmesystems.net/
(1,482 Views)
Thank you for your response. yes slot one is controller 8820. If I connect chassis to a monitor it states welcome to Labview Real-Time 15.0 and also IP address , mask.
Now what I have to do further with the IP address.
(1,477 Views)
