PXI
NI PCI 5640R not detected in Labview
I'm using a card NI PCI 5640R.
I installed NI-RIO 2.1 and the drivers for this card.
This latter is correctly detected in windows and in MAX, but I can't find it when I want to create a project with a FPGA target in Labview.
Can you help me ?
Xavier
(5,761 Views)
Hello to all
I have the same problem, I want also to say, that the Examples don't work, and if using VISA commands, there is the error this operation does not support.
Will be very appriciate for any help!
Help pleese!!!!!:):)
(5,169 Views)
Have you installed FPGA module for LabVIEW ? which version of LabVIEW have you installed ?
Have you installed the correct driver for the NI-5640R ?
You can download the version 1.2 on this link : http://joule.ni.com/nidu/cds/view/p/id/978/lang/fr, and the NI-RIO 2.4 on this link : http://joule.ni.com/nidu/cds/view/p/id/993/lang/fr.
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
(5,145 Views)
Yes, I have installed it, Ihave LabVIEW version 8.2.1
I have installed the driver, wich I have been taken with 5640R?
Thank you for the answer and links, I'll try:)
I realy want to know, what the problem is!!!:):):)
(5,114 Views)
Hi:)
I have LabVIEW version 8.2.1Full
I also want you to show 2 another errors
(5,106 Views)
I have the same problem with the software of LabVIEW 8.5,LabVIEW FPGA 8.5,NI RIO2.3.1 and NI 5640R 1.2
I deleted the RIO 2.3.1 then reinstall the NI 5640R 1.2, the bug fixed.
it seems that the NI 5640R 1.2 must install before RIO.
CLA & CLED
(4,725 Views)
Hi!
Does the 5640R correctly views in Max??
May be some answers you will find at
If there is more problems, write to dingo550@yandex.ru
Regards:)
(4,548 Views)
