Hi
I have a NI PXI 1052 chassis with NI PXI 8186 embedded controller, and the a NI PXI 6280 m series DAQ card, placed in the 4th slot of the chassis, in the SCXI slots i have 8 signal conditionig modules NI PXI 1125 with terminal box 1328. I am trying to configure this chassis using MAX, when i select the "new daqmx device" and select 1052 chassis and select auto detect modules, the modules are not getting detected, and when i manually select the modules and the accessories and test the chassis, it says there are no modules in the slot, what am i doing wrong, i have switched on the scxi switch at back of the chassis. Is there any other aspect to be taken care of before i configure this setup using MAX. Thanks for any answers,
Grazie e' mille'
Arun
