PXI
NI PXI 4132- Soft Front Panel- Sweep mode is not enabled
I have NI PXI-4132 installed in NI PXIE 1073 chassis. I am not good at programming. I am desperately looking automated software for measurement. I found NI Power Device Soft panel can do sweep measurement. But After device driver install , i have install Power device soft front panel. But unfortunately the sweep mode is disabled , i can not see , only source and sample mode is enabled, please help. BTW if anyone have Vi for sweep measurement using NI SMU please share with me if possible.
Atanu Das
(2,325 Views)
In both Instrument studio and DC power soft front panel the sweep mode is disabled, only Measurement and sample is available, I have tried a lot of it is not coming.
Please suggest if anyone face such issue.
Thanks.
(2,367 Views)
I suggest opening the LabVIEW example finder and searching "sweep". I was able to find several example VIs for the 4137.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIcjSAE&l=en-US
(2,262 Views)
What version of the front panel do you have installed? You can find this from the File menu by selecting Preferences and then About.
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(2,230 Views)
