PXI
NI-PXI-6289 Analog Out
Can the NI-PXI-6289 Analog Out signal be set to trigger from an input from one or four input signals received by the NI-PXI-6289 Analog Differential input channels? I am monitoring a signal using a differential channel from the NI-PXI-6289. I want to use that signal to trigger an analog channel from the NI-PXI-6289 to turn on a power supply.
(2,062 Views)
As detailed in the PXI-6289 Manual, the device does support analog triggering, and the source can be any of the AI channels on the device.
Lindsey Nestor
Program Manager, Hardware Services
(1,988 Views)
