PXI
NI PXI-8101 RT
Hi!
There are two version of this controller:
780955-33 NI PXI-8101 Celeron 575 2.0 GHz Real-Time Embedded SW
and
780956-33 NI PXI-8101 Celeron 575, 4 GB (or Greater) Flash HD, RT SW
What is the difference between its?
Is the "4GB flash" in the 780956-33 controller a "regular" CF card. Can I replace it by the CF card with 64GB capacity?
Jury
(4,188 Views)
Hello Poklad,
Thank you for bring this issue to the forums. The difference between the two are as follows:
1. 80955-33 NI PXI-8101 Celeron 575 2.0 GHz Real-Time Embedded SW
This will have an 80 GB Serial ATA Hard Drive minimum.
2. 780956-33 NI PXI-8101 Celeron 575, 4 GB (or Greater) Flash HD, RT SW
This will have a 4GB Flash Drive minimum.
Everything else between these to controllers are the same and yes, you can upgrade the 4 GB Flash Drive to a higher volume drive
Thank you,
Vimal Fernandez
Applications Engineer
(4,181 Views)
Hello Poklad,
Regarding your question on the type of flash drive, it is not a CF card. It is a 2.5" drive (typical laptop drive form factor).
(4,170 Views)
Hi!
I.e. this is 4 GB flash drive with SATA interface?
Jury
(4,168 Views)
Yes, it is a SATA interface.
-JoshH
(4,164 Views)
