11-11-2011 01:21 AM
Hi!
There are two version of this controller:
780955-33 NI PXI-8101 Celeron 575 2.0 GHz Real-Time Embedded SW
and
780956-33 NI PXI-8101 Celeron 575, 4 GB (or Greater) Flash HD, RT SW
What is the difference between its?
Is the "4GB flash" in the 780956-33 controller a "regular" CF card. Can I replace it by the CF card with 64GB capacity?
Jury
11-11-2011 03:32 PM
Hello Poklad,
Thank you for bring this issue to the forums. The difference between the two are as follows:
1. 80955-33 NI PXI-8101 Celeron 575 2.0 GHz Real-Time Embedded SW
This will have an 80 GB Serial ATA Hard Drive minimum.
2. 780956-33 NI PXI-8101 Celeron 575, 4 GB (or Greater) Flash HD, RT SW
This will have a 4GB Flash Drive minimum.
Everything else between these to controllers are the same and yes, you can upgrade the 4 GB Flash Drive to a higher volume drive
Thank you,
Vimal Fernandez
11-14-2011 01:02 AM
Hello Poklad,
Regarding your question on the type of flash drive, it is not a CF card. It is a 2.5" drive (typical laptop drive form factor).
11-14-2011 01:13 AM
Hi!
I.e. this is 4 GB flash drive with SATA interface?
Jury
11-14-2011 07:38 AM
Yes, it is a SATA interface.
-JoshH
