10-15-2011 06:54 AM
How, can I upgrade the configuration of the NI PXI-8176 from RT 8.5.1 to LabVIEW RT 2011?.
The chassis where the NI PXI-8176 connects, is the model PXI-1002
Simbani
10-17-2011 02:50 AM
you need a Target CD as described here:
http://digital.ni.com/public.nsf/allkb/C48FC4B99E3AFF85862574AB0074CCB5?OpenDocument
After installing LabVIEW and LabVIEW RT 2011, I think you could create a format floppy disk o USB device in MAX so as to format your controller with the newer version of LabVIEW.
