PXI
NI PXI 8310 Controller
I am using NI PXI 1036 DC chassis. I had used NI PXI 8310 crad bus and star fabric interface. I couldn't find out the NI PXI 8310 card on my device manager list.
(4,032 Views)
Good moring vtrivedi,
Thanks for contacting National Instruments with your issue, we'll try our best to resolve it for you as quickly and efficiently as possible.
The PXI-8310 serves as a PCI-to-PCI bridge, effectively "fooling" your controlling computer into thinking it has a large PCI bus than it does.  The only way to verify that the PXI-8310 has been installed correctly is as stated in the PXI-8310 User Manual on page 2-8 and 2-9.  Essentially it will show up as a StarGen PCI to PCI bridge.
If it's not showing up there, it could be an issue with either your version of Windows (Make sure you get SP2) or a boot up ordering issue.  Make sure you always power up your PXI chassis first and then your laptop (or whatever computer you're using to controll the chassis).
Best of luck with your project.
Sincerely,
Minh Tran
Applications Engineering
(4,013 Views)
