PXI
NI PXI-PCIe 8361 card not detected
Nicely done!  Multiple things to try here the next time I can get the new PC back in the test stand.
Message 11 of 12
(3,081 Views)
IcyMountain,
The LED behavior you describe sounds like a bad cable.  Early cables could be plugged in upside down, which would deform the D-shell a little and make it easier the next time.  Look closely at how the two sides are connected, because that gives the LED behavior you described.
- Robert
THIS!!!  D-Shell has been deformed and is now rectangular.  Some people are not as careful as I am.  When I reinstalled the new PC in this fixture, I made certain that the connection was correct.  Working now, thank you.
-Icy
Message 12 of 12
(3,038 Views)
