PXI
NI-PXI analog I/O range configuration
I'm currently developing control of voltage source in LabView 2012. The voltage and current limitation of each channel of the source is controlled by analog outputs of FPGA of NI-PXI. However the resolution of the outputs is only 16 bits. Is possible to reduce the output range to gain higher sensitivity. In FPGA I/O palette, I have found the I/O settings but there is no option to configure range. Is possible to change the range in my FPGA Target application?
Thank you replies
(3,912 Views)
After reading again the documentation, I found out that the analog outputs have fixed range, therefore it can't be changed.
(3,898 Views)
