PXI
NI PXIe-1073 connection to PC / Laptop - MXI-Express x1 to PC
We have got NI PXIe-1073 with MXI-Express x1 and installed NI PXI-2501 FET Multiplexer & NI PXI-4072 6 1/2 Digit Flexx DMM cards which we need to use and connect to the modern PC / Laptop without ExpressCard or PCI-Express.
Is the "ExpressCard - 8360 MXI-Express Interface" is the only option to get it connected to the PC / Laptop?
Can the "ExpressCard - 8360 MXI-Express Interface" be used together with the "ExpressCard to USB" adapter to make it work?
In addition, would we be required a sort of a licence for the DMM to use?
Any recommendations are welcome!
Thank you in advance.
Best Regards,
Jev
(3,255 Views)
Accepted by topic author jev.k
Hi Jev,
Hope you're well!
Regarding connecting the PXIe-1073 to a host PC/laptop; you're going to need something that supports the MXI-Express x1 from the host PC. This is the ExpressCard-8360 for a laptop or the PCIe-8361/8362. Alternatively, you could use a thunderbolt remote controller (PXIe-8301) in a different chassis if you have a native Thunderbolt 3 connection.
I'm afraid I can't comment on an adapter; my instinct would be a "no", as the MXI kit uses the PCIe switches/bridges to enable control, and I don't think an adapter could give this hardware interface / the speeds required for communication. I'll let another community member answer that though 🙂
Regarding the DMM - you'll need the free driver NI-DMM, which can be used with a variety of languages (LabVIEW, Python, C#, .NET etc).
Cheers,
Nick
(3,209 Views)
Sorry... one more question, you have mentioned that using NI-DMM driver makes it to connect with the LabView. But does NI provides a simple GUI in order to capture data from the DMM? Basically, we just need an accurate DMM (which is NI PXI-4072) to see the data on the screen (as a graph) and capture it into CSV file. As the LabView will require a paid license to use.
(3,160 Views)
Heya,
NI-DMM also has InstrumentStudio, which would match your needs.
You can read some more info here.
Cheers,
Nick
(3,150 Views)
