PXI
NI PXIe-1085 Power light solid red
When I turned on NI PXIe-1085 3 green led blink then power light get solid red according to manual its power supply failure. Bought a new power supply but didn't fix the problem anybody had this problem before.
Thank You
(1,552 Views)
Were you able to measure each supply rail on the voltage monitor connector on the back of the chassis?
Santhosh
Soliton Technologies
(1,511 Views)
Sir I haven't but I will do That Today
Thank You
(1,506 Views)
Between the pins
1-8             5.072 Vdc
2-8             5.072 Vdc
4-8             0        Vdc
5-8             0        Vdc
6-8             0        Vdc
7-8             0        Vdc
I also checked on start up none of the needed pins have power
Okay i pulled the fans and power supply out turned fans on manually
1-8             5.072 Vdc
2-8             5.072 Vdc
4-8             5.6     Vdc
5-8             3.6     Vdc
6-8             12.48 Vdc
7-8            -11-99 Vdc
(I have pulled all the cards, and used know good HDD 8261 4 drive storage and the PXI 8840 Quade Core, before i posted about this problem)
Thank You in advance
(1,501 Views)
I am sorry, a bit lost, what is the observation?
After you press the power button, power rails are good or bad?
Santhosh
(1,494 Views)
I only get power on the back pins when i switch fans to manual and have the back part of the chassis pulled out so not connected to front part chassis.
top numbers are when its all together
bottom is when i pulled the power supply out with the fan assamble
Thank You
(1,490 Views)
