08-03-2025 08:23 PM
PXIe-1085 장비의 스위치가 게속 눌리는 현상이 간혹 생겨서 전원이 꺼지는데
전원스위치만 교체할수 있을까요? NI 측에 맡기려고하니 가격이 너무 비싸네요ㅠㅠ
가능하다면 구매가능한 링크도 공유해주세요.
08-04-2025 09:29 AM
@jaehyoung_shin wrote:
The switch on my PXIe-1085 device occasionally keeps getting pressed, causing it to power off.
Can I just replace the power switch? I'd like to have NI do it, but it's too expensive.
If possible, please share a link where I can purchase it.
I am not aware of where you can get the power switch externally.
Another alternative is to use Remote Inhibit, which allows the power switch to be controlled remotely, perhaps by your own external switch.
08-04-2025 07:40 PM
Thank you very much for your detailed and helpful response. I truly appreciate your suggestion to use the Remote Inhibit feature as an alternative solution.
