PXI
NI PXIe-6345 digital signal edge detection
Im trying to detect the falling edge of the digital signal coming in Dev1/port0/line0 of NI-6345 using NIDAQMX python library.
This is my code snippet
    with nidaqmx.Task() as task:
        channel=task.di_channels.add_di_chan(channel)
        task.timing.cfg_change_detection_timing(rising_edge_chan="/Dev1/port0/line0",
                                                falling_edge_chan="/Dev1/port0/line0",
                                                sample_mode=AcquisitionType.CONTINUOUS)
        start=time.time()
        while True:
            sample= task.read()
            print(f"Falling edge detected: {sample}")
            break
        difftime= time.time()-start
        print("difftime=",difftime)
but I'm getting the following error
Traceback (most recent call last):
  File "/home/user/measurePulse.py", line 201, in <module>
    waitUntilSignalTransition()
  File "/home/user/measurePulse.py", line 95, in waitUntilSignalTransition
    sample= task.read()
  File "/home/user/.pyenv/versions/3.10.7/lib/python3.10/site-packages/nidaqmx/task/_task.py", line 623, in read
    _, samples_read, _ = self._interpreter.read_digital_lines(
  File "/home/user/.pyenv/versions/3.10.7/lib/python3.10/site-packages/nidaqmx/_library_interpreter.py", line 4541, in read_digital_lines
    self.check_for_error(error_code, samps_per_chan_read=samps_per_chan_read.value)
  File "/home/user/.pyenv/versions/3.10.7/lib/python3.10/site-packages/nidaqmx/_library_interpreter.py", line 6408, in check_for_error
    raise DaqReadError(extended_error_info, error_code, samps_per_chan_read)
nidaqmx.errors.DaqReadError: A hardware failure has occurred. The operation could not be completed as specified.
Task Name: _unnamedTask<0>
Status Code: -50152
I'm a bit new with NI cards, and I couldn't figure out if the NI6345 digital lines can detect edges.
Any help on this matter is greatly appreciated
(527 Views)
What do you want to do after detecting the falling edge?
Santhosh
Soliton Technologies
(513 Views)
I wanted to detect the falling edge of the signal and return from this function.
(489 Views)
So, you need a way to detect a digital edge transition to proceed/do something in software.
Santhosh
(477 Views)
Exactly
(472 Views)
