PXI
NI PXIe 6363 Analog Output
We are using NI PXIe 6363 DAC module in one of our project.
We are in need of connecting 10V DC input into one of the analog output channel to test one certian test case.
By injecting 10V DC into an Analog Output channel will have any impact / damage o the card?
(2,777 Views)
Applying voltage into the Analog Out port might damage the card. Why would you want to try this??
Refer to the input and output impedance values for the PXIe-6363, as well as the over-voltage protection specifications.
(2,753 Views)
