PXI
NI Scope 1.6 shows Error while running
When I bring my NI Scope 1.6, the word Error in red is displayed in the right top most corner of the scope display. Also the scope application does not display any signals.
(3,051 Views)
Hi CEY,
You are using fairly older version of the NI Scope SFP, so i would suggest upgrading to the newest version 2.3. You can download the latest version of the Scope driver here and this will automatically download the latest version of NI Scope SFP.
Also, is there an error code or some sort of description associated with the error that you are getting? What type of hardware are you using with this software? Can you give us a little bit more description on what you are trying to accomplish with your test/application? Was the software working correctly before (or with other hardware)? What has changed since the error started occurring?
Natasa
(3,036 Views)
