PXI
NI Scope not seeing cards after new card installed
I have a PXIe 1073 chassis and had two PXIe 5114 2 channel scopes installed on it.  Everything worked as expected.  I recently added a PXIe 5160 (4 channel scope) and not NI-Scope soft front panel won't see any cards in my chassis (error pop-up in atachment, but it just says it doesn't see anything and asks to rescan).
I see the chassis and the three cards in the NI-MAX but I feel like I used to see more information about the chassis and cards (like the card temperatures) before so I feel like something is off.  I attached two screen shots of what I see in NI-MAX.
I am not even sure what to try to debug this problem.  I updated the NI-Scope from 14 to 15 hoping that would help but that did not change anything (the problem happened before I upgraded, not just after).  If you want me to try anything and report back I will gladly do that.
Thanks for all the help in advance.
(3,201 Views)
Hi GreenRiver,
Looking at the pictures, this looks like there might be an issue with the MAX database. Take a look at your USB devices, those look like something went wrong there too. In the link, you’ll find the steps for resetting the MAX database. Give that a try and let us know how it goes.
http://digital.ni.com/public.nsf/allkb/2C7480E856987FFF862573AE005AB0D9
(3,176 Views)
