09-19-2017 01:34 PM
Dear all,
We have just bought a brand new terminal block NI TB 4330 (to replace the damaged one) which is mounted on a NI PXIe 4331 for a PXI 1073.
I have run the VI with the brand new terminal this morning to run two load cells. It worked, I stopped the VI, I run it again and it didn't. I have run the VI 20 times and it didnt work. It says 'unsupported device' is presented. I turned the PC off then turned it on again. The TB NI 4330 terminal block was not appeared in MAX. Can someone tell me how the terminal can be viewed in MAX and what is wrong with this issue?
P.S. The bridge module NI PXIe 4331 passes the self-test in MAX.
REgards,
09-19-2017 02:39 PM
I have just turned on the PC and the brand new terminal block shows in MAX with an X next to it. Again, the VI does not run as it was previously used to run.
