PXI
NI-VISA PCI driver with interrupt detection
HI Yan,
Those bars just show the instantaneous percentage of CPU time that is spent running Interrupt Service Routines, regardless of the source. If you can force a large amount of interrupts to be generated, then you should be able to see a spike.
Trevor B.
PSE
Message 11 of 12
(2,902 Views)
Hello Trevor,
I have worked out the interrupt detection issues and I use the Callback Mechanism to handling the interrupt. However, I want the interrupt service routine (ISR) to be executed in 1ms. How does labVIEW RT can ensure it ?
Thank you,
Yan
Message 12 of 12
(2,849 Views)
