PXI
NI-VST self-calibration
The self-calibration utility for the VST (niVST Self Calibrate.exe) has an "Abort" button.  Is it possible to abort a self-cal which has been started by calling the niVSTCal_SelfCalibrate function in niVSTSelfCal.h?
(4,265 Views)
Accepted by topic author Tevildo
Hi, where do you find the niVST Self Calibrate.exe ?
I notice that the VSTSelfCalibrate function in LabVIEW (Instrument I/O»Instrument Drivers»NI VST Calibration»Self-Calibrate.vi does not have an Abort input, so I'm guessing that the text-based equivalent also doesn't have this option.
Amy K
National Instruments UK & Ireland
(4,214 Views)
Amy
On my system, it's in C:\Program Files (x86)\National Instruments\NI VST\Self Calibration .  I believe it's installed as part of the RFDRVSuite package.
(4,211 Views)
