PXI
NI Variable Engine:Error:
Hi TurboPhil,
What version of the LabVIEW Real-Time Module are you using with your PXI-8106 systems? Are you accessing them from the same desktop PC that you accessed your PXI-8110 system with?
Casey Weltzin
Product Manager, LabVIEW Real-Time
Message 11 of 15
(2,153 Views)
Hi TurboPhil,
I have confirmed that the PXI-8106 does not yet support the Reliance file system (a BIOS upgrade is needed). We are working on incorporating this support into the BIOS, and so I would encourage you to check back or look for newly released BIOS code on the ni.com website periodically.
Please let me know if you have any additional questions, and have a great day!
Casey Weltzin
Message 12 of 15
(2,139 Views)
Matt,
I am using a PXI 8106 and last week, I got the exact fatal error codes as teritask described. Once I rebooted the host and RT, started working fine and I am able to run test cases.
Also the symptom that as said in the knowledge base article -
"One sign that your database may be corrupt is if you click on the plus sign for a folder in MAX and if instead of expanding the plus sign disappears. " - this is not happening with me. All folders expand correctly on the + sign and + sign stays.
Should I still do the correction procedure?
Message 13 of 15
(1,663 Views)
Hi Sumithra,
Following your reboot, have you expereinced any further errors or signs of impropper functioning of the device?
Michael G
Michael G.
Self-realization: I was thinking of the immortal words of Socrates, who said, "... I drank what?"
Message 14 of 15
(1,648 Views)
No I have not.
Message 15 of 15
(1,644 Views)
