PXI
NI Variable Engine error when PXI is booted
Hi my name is Padraig Walsh and i am a student in Cork Institute Of Technology, Rossa Avenue, Bishopstown, Cork, Ireland.
I am getting the following error message on my PXI system every time i boot it up.
NI-VISA Server 4.3 started sucessfully.
NI Variable Engine: Error: Unable to load the MXS configuration plugin: Failed to get MAX Configuration interface 0x80004005
NI Variable Engine: Error: c:\ni-rt\system\ni_tagger_plugin_nxs.dll: Failure to load plugin: Unexpected Error: Unable to get the interface from the plug-in.
I recently installed LabVIEW 8.5.1 and i have been receiving this message since.
I am attaching error logs and screen shots that might be of help.
If you have any ideas i would like to hear from you.
Thank you!
(4,215 Views)
Hi Padraig,
Please can you reinstall all the RT software onto the PXI RT system from the machine that you installed LabVIEW 8.5.1 on.
I also assume you upgraded to LabVIEW RT 8.5.1 at the same time. You would normally see the error you are getting because of a version mismatch with the different software components.
Regards
JamesC
NIUK and Ireland
It only takes a second to rate an answer 🙂
(4,197 Views)
Hi JamesC,
I have installed the Student Edition of LabVIEW 8.5.
Now everytime I boot my computer the following error message appears on the desktop: Variable engine caused a failure! (I translated this from the german message)
My System:
Windows XP + SP3
DELL XPS M1530
Do you think its the fault of SP3?
I hope you can help me!
Best regards
Georg
(3,974 Views)
