PXI
NI Veristand 2018 error 307703
regards
I try to execute an example of national instruments, to be more specific, the example of MIL, this tutorial that I found on you tube and was loaded by national instruments, running it on Windows as a controller, there is no problem, the problem arises when I try to to run on a PXI 1042 in real time, I've already installed veristand in pxi,also LabWindows 17  RT
I have
veristand 2018 spi
labview 2018
NI PXI 1042
LabWindows ™ / CVI Run-Time Engine for RT 17
The link in the example is as follows:
https://www.youtube.com/watch?v=wvDpVpyD68A
The error code is 307703
(2,677 Views)
this is the complete error code:
The VeriStand Gateway encountered an error while deploying the System Definition file. Details: Error -307703 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi Possible reason(s): NI VeriStand: The specified model is incompatible with NI VeriStand. If you are trying to deploy the model to an RT target, launch the Console Viewer tool to display the console output of the target, which includes information about the source of the error. ========================= NI VeriStand: NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi >> NI VeriStand Engine.lvlib:VeriStand Engine.vi >> NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi >> Model Execution.lvlib:Initialize Model Loop Data.vi >> Model Execution.lvlib:Initialize Models.vi >> SIT Model API.lvlib:Initialize Model.vi <append>========================= NI VeriStand: Initialization error code 1 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * • Sending reset command to all targets... • Stopping TCP loops. Waiting for TCP loops to shut down... • TCP loops shut down successfully. • Unloading System Definition file... • Connection with target Controller has been lost.
(2,676 Views)
Hello EDGARGABRIELHERNANDEZ,
Thank you for using the National Instruments forums. Regarding your question, please check if the Model name has some special characters, if there are special characters please try to change the name. If that doesn´t work please try to move the model to other folder, or other location, sometimes the path of the model could generate this problem. If that doesn´t work you can try to format the PXI and reinstall the software, this to be sure any corrpuption exists in the software.
Please let us know your results with these tests.
Regards!
Edgar Rosales
Ingeniería de Aplicaciones
(2,623 Views)
