PXI
NI daq mx advanced time setting
Dear sir,
I am measuring Analog Voltage input In PXI-1050 chasis through SCXI 1125 module(1325 terminal block). I am using
NI DAQmx platform. I have used Daq assistant VI for analog input voltage ,and i am writing the voltage against time in
Write VI i,e lvm file. As M series DAQ module 6250 is there in last slot of PXI which is 16 bit. so I hope it should write
65536 saples at the given sampling frequency in LVM file. but when I am providig no. of samples to write as 65536
it is writing the data for only 10 second like if my freq. is 2000 it can write data only 20008. What modifications I should
do so that i can able to write more data ... please give me suggestions.....
Thanks.....
balasaheb
Message 1 of 1
(3,123 Views)
