PXI
NIHSDIO - get session reference
i have a problem with the get session reference of NI-HSDIO (PXI-6541) in PXIe -1082.
In the PXI was installed in the past Labview 2010 and all is working. Now I installed LABview 2011 and I get the error in the attached file. I tried to delete the reference and create another with rightclick, but I see fields gray only.
If I try the same library of ni-HSDIO in a computer where the first version of Labview installed is 2011 it works.
In the PXI I don't tried to remove the 2010 release because I have the suspicion the code of ni-HSDIO developed with 2010 are not working in 2011 release
Can someone help me?
(4,623 Views)
Hi Peppe,
what you are seeing is very similar to what is described in this post:
http://forums.ni.com/t5/PXI/hsdio-vi-broken/td-p/1698166
Please verify that the HSDIO.dll is not missing from the folder in
"C:\Program Files\National Instruments\LabVIEW 2011\instr.lib\niHSDIO\niHSDIO.dll".
If so, I think this could be an installation related issue. Please try repar your installation or manually copy the dll to the folder above.
Hope this helps,
Clara
(4,605 Views)
