PXI
NRZI encoding in PXI-6570
Is there a way to implement NRZI encoding into the pattern and something like raw binary to NRZI during sourcing the source waveform. I know we can do it while writing to source waveform itself, I just wanted to know if there is a way to add this configurablilty to the same, adding mods etc..,
This will basically help me in implementing real-time parity embedded into my patterns etc.,
(1,317 Views)
No, it is not inherently supported at the hardware or driver layer, it has to be encoded at the application layer.
To perform real-time parity you need an FPGA, the 6570 is pattern-based instrument with limited FPGA-like on-the-fly customization of the behaviour (limited to flow control).
Santhosh
Soliton Technologies
(1,304 Views)
