PXI
Noise Floor vs Amplitude Graphs at Additional Frequencies for NI PXIe 5433
Hi NI Community,
I'm currently working with the NI PXI 5433 and referring to its datasheet for signal characterization. I noticed that the datasheet includes noise floor vs amplitude graphs for only a few specific frequencies—namely 1 MHz, 5 MHz, and 10 MHz.
However, the table above these graphs lists several other frequencies for which similar data would be extremely helpful. Is it possible to obtain noise floor vs amplitude plots for those additional frequencies of  3 MHz, 20 MHz, 30 MHz, 40 MHz, 80 MHz ? If these are available in an extended version of the datasheet or through any other documentation or measurement reports, I’d greatly appreciate a pointer.
Thanks in advance!
Attaching the image for the reference.
Message 1 of 1
(150 Views)
