PXI
One of two CAN Port doesn't work
Today i was trying to make a CAN Loopback Test with the VI from National Instruments but I didn't succed. I thought I had the Interface names and yes I  had them wrong.
I looked in the RT Hardware Configuration and tested every port and the Port1 is ok but the Port2 apparently not.fail.PNG
Does that mean that my Can port in my PXI-8512 Card doesn't work and there is no way I can fix it?
Or could it be that I didn't installed the right drivers?
Could it be a "software" problem?
What would you do in my place?
Thanks.
Regards.
My Channel: https://www.youtube.com/@LV_Lab
(2,827 Views)
Could you click on "Port2" and share similar screenshot? Thanks!
Best Regards,
TK
Certified LabVIEW Architect (CLA)
(2,773 Views)
 Here it is.
Interface Name: CAN1
Transceiver: High Speed
Transceiver-Name: Unknown
Baudrate: 125kBaud
Status: Failed
Verification failed; double click 'Status' for more information
When I do double click I get the following text:
Error code 7, identifier 0
Software problem occurred. This error occurs when a test can not communicate properly with the hardware and software installed.
Please restart your computer and re-run the test. If the problem persists, make a note of the numeric code included with the computer the error is reported and contact National Instruments.
Regards
(2,767 Views)
