PXI
PCI-6221 and coordination with Labview
Hi!
At the mometn i have PCI-6221 board for reading some values and this board worked with Labview 8.5 version.
Could you tell me that how can i change version Labview 8.5 to more largest and work with this board?
Thank you!
(2,343 Views)
According to the latest version of DAQmx (19.6) Readme, the PCI-6221 is still compatible.  DAQmx 19.6 is compatible with LabVIEW 2016 through LabVIEW 2019.  So if you want the latest, just use LabVIEW 2019 with DAQmx 19.6.
(2,326 Views)
So, if i installed Labview 2019 and DAQmx v19.6 i can succesful use PCE-6221 board?
(2,315 Views)
Yes.  Do note that you are skipping over 10 years worth of updates here, so there will likely be caveats that you will have to fix.  Also note that the PCI-6221 is listed as "Mature", meaning it will soon be considered obsolete.  So you might want to start the plans to upgrade hardware as well.
(2,310 Views)
