PXI
PCI/PXIe-2532B Matrix Expansion Ribbon Cable intermittent connection due to loose cable solutions
In our PXI matrices we have seen a lot of issues with the Row cables getting loose and causing failures that even though they are simple to fix, it is not fast and we believe that the strain relief is not doing its job.
We have a tester cabinet where the door when closed sits to close to the ribbon cables, so it could be pushing them.
Has anybody encountered this issue, if so how did you solve it? We have been thinking about using some type of glue to hold the connectors in place, but please advise if NI has a recommended type or brand.
Message 1 of 1
(4,486 Views)
