โ04-28-2022 07:33 AM
Hi people.
I have a motheboard with one PXI-E x16 Gen 3 slot.
But I didn't find any information about compatiblity of this device with motherboards. ๐
I know about NI Compatibility Software. But it requires to have a physical board.
My goal is to be 100% sure that selected device for PXI Remote Control will be compatible with my motheboard. ๐
A there list of compatible motherboards and BIOS versions for PCIe-8398?
My motherboard is ASUS PRIME H510-M-K;
โ04-28-2022 09:21 AM
@alex_whiteknife wrote:
Hi people.
I have a motheboard with one PXI-E x16 Gen 3 slot.But I didn't find any information about compatiblity of this device with motherboards. ๐
Unfortunately, No. There are literally thousands of motherboard models across a few hundred different manufacturers, NI could not practically buy and test every single one (btw there might be a new motherboard introduced every day somewhere in the world).'
As a side note, BIOS is developed specifically for a motherboard(s) and chipset(s) combination, hence it is not universally comparable with just version (like a tailored shirt)
All that you can verify is whether the motherboard has the PCIe slot required by PCIe-8398.
An easy option to avoid all these uncertainties is to get a PXIe embedded controller (this is for sure 100% tested by NI and compatible with the chassis).
