PXI
PFI output level
I'm setting up a system in which I would like to use a marker sent using the PFI0 output of an arbitrary waveform generator (5441) to trigger an external equipment (Tektronix PSPL10070A pulse generator), which requires a +-2V signal. Is this something I can do using the PFI0 output? I haven't been able to figure out how to change the output voltage of this port.
Any help is greatly appreciated.
Michael
(2,356 Views)
Hi Michael,
That is something you can do. Please see the white paper below for more info on triggering. I also suggest looking at our help documentation and LabVIEW examples.
Advanced Waveform Sequencing and Triggering on Arbitrary Waveform Generators
http://www.ni.com/white-paper/5534/en/
Best,
Misbah
(2,327 Views)
