PXI
PIX-8108
I am using NI PXI 8108 Embedded controller which is Windows 7 professional configured.When it is powered ON starting it shows following error,
"This error can be caused by unplugging a removable storage device such as an external USB drive while the device is in use, or by faulty hard ware such as a hard drive or CD-ROM drive that is falling make sure any removable storage is properly connected and then restart your computer.
if you continue to recevive this error message,contact the hardware manufacturer
file:\boot\BCD
status:0*c00000e9
info :unexpexted i/o error has occured."
when i try to install windows 7(32 bit professional)  pxi system back up DVD ,after selecting one primary drive of size 120 GB,during installation sequence,followingerroriscomming,
"Windows can not  install required files make sure all files required for installation available and restart the installation.
Error code:0*8007045D"
any sugesstion for rectifing this error.
Message 1 of 1
(5,417 Views)
