PXI
PX2000-107 Development Breadboard results in Windows XP locking up
I have installed a PX2000-107 (from PX Instrument Technology) in a couple different PCs running Windows XP. One of the PCs is experiencing lock ups (screen freezes and OS is nonresponsive to mouse and keyboard). The PX2000-107 card is installed in a PXI chassis controlled through a MXI 3 link from a Windows XP PC. Note that this card has been sucessfully installed and controlled in a similar PXI chassis controlled via MXI 3 link from a similar Windows XP PC. I have replaced the suspect PX2000-107 card and have the same problem. Does anyone have suggestions as to where I should start troubleshooting?
(3,131 Views)
Hi Randy,
Is this a National Instruments MXI-3 card and PXI chassis? If so, what model? Is there software (other than the driver) that came with the PX2000-107 board? If so, have you uninstalled/reinstalled the software? You could also try the uninstall/reinstall of the driver as well. Can you see the PX2000-107 board in hardware device manager and does it have a yellow exclamation mark next to it?
Hope this helps!
Brooks W.
(3,115 Views)
