PXI
PXI-1000B to calibrate Signametric DMM's?
I'm new to this PXI stuff.  We have an NI PXI-1000B with an MXI-3 (interface?) card, and Cal. Exec. 2.0 on the PC.  Is there any way (upgrades) to uses this to calibrate Signametrics DMM's?  The PC is connected to a Fluke 5700 calibrator through the GPIB.
Bob
(3,960 Views)
Hey Bob,
I just want to make sure I understand your question.  Are you asking if Cal. Exec 2.0 can be used to calibrate a Signametrics DMM?
Jason W
(3,951 Views)
Hi Jason:
I think the answer to you question is yes.  Can I use Cal Exec 2.0 to calibrate Signametric's DMM's (SMX-2064), and if not, will the latest version of Cal Exec (3.2?) do the trick.
(3,940 Views)
Hey Opabob,
Thanks for contacting National Instruments support.  CalExec is used to calibrate National Instrument products, we do not, at this time, support any other products for calibration.   We also have no furture plans to do so.  You will need to calibrate your SMX-2064 by some other means.
Kenn North
Principal Product Manager - Search, Digital Analytics
http://ni.com/search
(3,923 Views)
