PXI
PXI 1010 Chassis power failed.
Now one PXI 1010 backplane power failed on PXI section, but SCXI side can power on.I ever checked nad reset circuit breaker, no help. I need your help! Who will give me a kind hand?
(3,876 Views)
Roger,
If you have already checked the circuit breaker and have verified that it is not tripped, more than likely there is a power failure with the PXI portion of the power supply. I would create a phone service request at www.ni.com/ask. We can only handle returns through our phone support. At that point, if you indicate that you have a damaged product, we can work with you to get it fixed.
Andrew M
(3,876 Views)
Thanks for your answer.
As you suspected,the power supply(APS,
MFS50-DHW0) has no output.Also, I found one broken
fuse(F2) on its inside board. But who can tell its specification?
(3,876 Views)
